HI All,
Now that I have an almost complete beosystem 4500 (beomaster, beogram, beogram CD + red-line 60.2, beolink 1000 + 7-pin extension cords from Steve) there is one annoying issue when listening to vinyl records: the volume is significantly lower than with other sources (be it tuner, CD or other sources on AUX). When switching to phono, I have to increase the volume by 15 or 20 units !
The beogram 4500 has an MMC4 refitted from AXEL in Germany and the sound is ok. Is there a way to increase the output level of the beogram (or is there a well-known internal component that is likely to be weakening the level)?
Alternatively, is there a way to 'simply' deactivate the in-built preamp in order to use an external one (I have one with adjustable output level)
Thanks for your advice
Thierry
Beogram 1600, Beogram 4500, Beogram 4500 CD, Beomaster 3500, Beomaster 4500, Beovox RL60.2, Beolink 1000
