Beovox 1001 how to change cables
This post has 4 Replies | 0 Followers
Juddly01
Posts 3
Juddly01 Posted: Fri, Feb 5 2016 8:33 PM
Hi I've recently aquired a beogram 1500 with Beovox 1001 speakers however one of the speakers has a damaged cable and i thought I'd replace both with newer cables. The problem is I'm unsure how to remove the front metal grill without damaging it or if there a way to get in via the back ? It does look glued in from the rear.
Dillen
Copenhagen / Denmark
Posts 13,191
Dillen replied on Fri, Feb 5 2016 11:38 PM
Welcome to Beoworld !
And what a nice vintage system! :-)
To get inside the Beovox 1001 (and 901), you will have to carefully ease the "rubber-like" plastic surround off at one end and
a little down both sides - just enough to slide the metalgrill that way out.
Then unscrew the woofer and swing it aside to access the innards.
You cannot get in from the back.
Juddly01
Posts 3
Thanks for the reply I don't know if I want to do that incase I I damage them I'm now considering maybe putting banana clips in to link the damaged secretions rather than opening them up. But will that cause a issue with sound quality?
Juddly01
Posts 3
Dillen
Posts 13,191
Dillen replied on Sat, Feb 6 2016 5:05 PM
If a length of cable is intact close to the speaker, perhaps you can extent the cables externally.
Page 1 of 1 (5 items) | RSS
