Hi All
I recently purchased a Beomaster 1400k together with Biovox 1200 speakers.
It all appears to be working fine and sounds nice. Radio works a treat and works well with a DIN to jack cable for laptop/ipod etc
the only thing is, the little light for 'stereo' is out (flickers on very occasionally) and the light on the radio tuner is out also.
Its not a big deal, but if it is easy to fix, it could be nice, but don't know how fragile the machine is and don't want to break it altogether for the sake of a light.
Can anyone offer any advice?
- does the front plastic panel come off easy to get acess to the lights?
-should the plastic panel be flush with the metal frame or should it jut out a little?
On mine, it is jutting out on the left side and flush on the right :) not sure if it needs pulling out or pushing in :)
Thanks for any help or comments
Daniel
Derby/Aalborg
