I have a Beogram 4002 where the wood panels have come off. Therefore I need to take off the metal thing on which the wood panels were attached to. It seems to consist of two pieces which are held by four (five?) washers.
I've managed to remove the left one but the other one seems to be attached under the keyboard.
How do I take out the keyboard?
/riis
A hidden screw sits under the speed dials.Just lift up the panel with the speed dials and fingerscrews.
Let Mika show you how::http://archivedarchivedforum2.beoworld.org/forums/t/27003.aspx
Dillen: A hidden screw sits under the speed dials.Just lift up the panel with the speed dials and fingerscrews. Let Mika show you how::http://archivedarchivedforum2.beoworld.org/forums/t/27003.aspx Martin
Thanks Martin. Now I can finish the cabinet.
