I noticed that when switching on the TV it starts playing at volume 45 which is too loud for us. It used to be at volume 35 previously. I am not aware of any changes to the settings.
Is there a way to set the default volume when switching on the TV? On my BV6-26 there is a setting to control this, but I can't find anything similar on my V1.
Do others also experience the same problem? Any suggestions how to solve this?
Jans
Hi Jans,
Go to:
MENU
SET UP
SOUND
SOUND ADJUSTMENT
change the volume to what you want it to be as default
presse STORE
next time you switch on the V1 it will use the volume you just set and stored.
Peter
thank you. It works!
Jan
