Has anyone attempted to remove the iPhone/ iPad dock on the Beosound 8?
I have mine wall mounted and only use it for airplay with Apple Airport express.
Beosound 8, Beotime, Beocom 4, Beo 5, Lutron Rania, MacBook 15" (Mid 2015), iPad Pro, iPhone 6S, B&O Play H3, Beolit 12, Form 2, A8 Headphones, B&O Play A1, B&O Essence
Damn Chris, you've been staring at that new A8 too much havnt you!
Which logo looks better on it? B&O or BANG&OLUFSEN? I still can't decide!!!
To remove it properly, you have to almost disasembly the BS8 totally.Both speakers and electronics has to be removed in order to take out the docking connector. And it will leave a hole
I think the BS8 looks better with an iPad connected. The A8 just doesn't look right without a dock or iPad (iPhone looks too small), although that STB stand does look good, I'll admit!
