Hello!Can anyone suggest any electronic curtains, that I can use with the Beolink app and integrate with my b&o products?
I`m using 24V blinds made by Somfy with a relay board 108 by Lintronic.
You can use it standalone for IR control directly via Beo4/6, BL1000... in LIGHT GREEN, YELLOW, BLUE, RED mode.
Works great. Or you can control the board via RS232 commands via the MLGW. that`s how I use it now, because it is possible to control the blinds from all over the house and it`s even possible to integrate the blinds into macros controled by the MLGW.
The Lintronic 108 board is for sale, because I`m expanding my KNX home automation system and I will use a KNX device to control the Somfy blinds.
Stefan
Why not go radio ra2? Easy integration and rock solid reliability?
