Does anyone remember how to change a Beolink 5000 from 2 way to 1 way operation?
shift menu
then > you get video terminal
with down one can switch to one way
accept with play
Just to clarify, you can actually chose whether AUDIO and/or VIDEO are ONE or TWO WAY
Having pressed SHIFT then MENU, you get a screen that states TERMINAL SETUP.
Press PLAY, then you get a choice of VIDEO ONE WAY, or TWO WAY - use up down arrows
Press PLAY, then you get a choice of AUDIO ONE WAY, or TWO WAY
Press PLAY to accept.
Many thanks
Ron
STD.BY -> Menu -> TRMINAL SETUP -> PLAY
Then change for AUDIO and VIDEO
http://www.bang-olufsen.com/da/customer-service/product-support/accessories/remote-controls/beolink-5000
EDIT : Apparently the userguide does not have this info, but you have already got your answer i see :)
/Weebyx
hello !
Hello ! I can't get into the nemu terminal setup in my beolink 5000...
please help me :)
As explained above, SHIFT followed by MENU should get you to the TERMINAL SETUP menu.
(in the manual it does also say to press the power button (red dot) first to switch the BL5000 to standby)
