Folks - looking for any suggestions. I am using beomusic iPhone for my A6. The app is able to find my audio servers (Windows 10). Will show songs but they are all greyed out and can not be selected to play. Any suggestions would be much appreciated.
Thanks,
Jim
make a TuneIn account on your PC
login on this account on the BP A6. Start a station.
thereafter you can access your server music files
That's bizarre...and it worked??? Do you know why?
Thanks!
jgreen8240: That's bizarre...and it worked??? Do you know why? Thanks!
Never thought of that.
I set up my Essence with TuneIN first thing, because I wanted the radio stations and because it was the first thing described in the setup advice. (I don't use Deezer at the moment.)
My DLNA servers - and the files - were there, when I came to looking for that.
