I'm new to both BeoWorld and BeoSound 5 Encore which I've only had for a few days. My question is this: I have a music library on a Windows Home Server 2011 running 24-7. All my music in mp3 format shows up fine on my BeoSound 5. I now started re-ripping to FLAC (using EAC) and I'm replacing my mp3 files. However, the FLAC files do not show up on the BeoSound 5 (I re-scanned the library from the BeoSound 5). Can anybody tell my what is going wrong - and how do I solve this problem?
Many thanks!
did you use mp3tag for the covers?
The problem is that the uPnP server in WHS does not support FLAC. Try installing another, e.g. Asset: http://www.dbpoweramp.com/asset-whs-manual.html
Magnus
Many thanks! Installing another uPnP server solved my problem.
Thanks for your answer, Koning!
