I have a speaker question unrelated to B&O speakers.
In our “media” room I combine a pair of Linn Isobaric speakers with a pair of McIntosh ML-2M speakers with an excellent over-all result.
However for some unknown reason the McIntosh speakers play at about half the volume of the Isobaric speakers, which makes no sense to me as the Linn’s are super power-hungry speakers.
The McIntosh ML-2M’s were designed to be used with an equalizer which I eliminated ages ago. I was considering purchasing a replacement until I researched it and realized the equalizer is designed to be placed in-line in-between the pre-amp and the amplifier, thus effecting both pairs of speakers, so that is a non-starter.
The advice I was given was: put the ML-2 on the 4 ohm connection and put the Linn on the 2 ohm connection, that will lower the output of the Linns by 3Db.
Does this make sense to you guys?
Currently both pair of speakers are on 8 ohm connections.
As a technical layperson this goes completely over my head. As such as it appears the 8 ohm connection provides the most power to the speaker, so I wonder why not leave the McIntosh speakers at 8 ohms and take the Linn’s to the 6 ohm connection?
Guys, I ask because I simply don’t know; however the advice I was given was from someone who should know….. but I really wanted to hear it from you.
Thanks for your opinions and patience with a non-B&O question.
Jeff
Beogram 4000, Beogram 4002, Beogram 4004, Beogram 8000, Beogram 8002, Beogram 1602. Beogram 4500 CD player, B&O CDX player, Beocord 4500, Beocord 5000 T4716, Beocord 5000 T4716, Beocord 5000 T4716, Beocord 8004, Beocord 9000, Beomaster 1000, Beomaster 1600, Beomaster 2400.2, Beomaster 2400.2, Beomaster 4400, Beomaster 4500, Beolab 5000, Beomaster 5000, BeoCenter 9000. BeoSound Century, S-45.2, S-45.2, S-75, S-75, M-75, M-100, MC 120.2 speakers; B&O Illuminated Sign (with crown & red logo). B&O grey & black Illuminated Sign, B&O black Plexiglas dealer sign, B&O ash tray, B&O (Orrefors) dealer award vase, B&O Beotime Clock. Navy blue B&O baseball cap, B&O T-shirt X2, B&O black ball point pen, B&O Retail Management Binder
Not a lot of interest in this question. Darn.
Guys I have conflicting advice from two electronic engineers and with engineers you don’t ask a question twice.
The situation is this, the two pairs of speakers compliment one another amazingly well, however the super power hungry Linn Isobaric play at, at least twice the volume of the McIntosh ML-2’s.
At a fairly high volume level, say 50 watts I can physically place my ear against the McIntosh tweeters/mid-range and ONLY then can I hear them working. At 150 watts the McIntosh speakers can easily be heard, BUT the Linn’s are way too loud.
Both speakers are wired to the 8 ohm connections, as both speakers are 8 ohm speakers.
The first suggestion I received was to change the Linn connection to 2 ohm and the McIntosh to 4 ohm, however my second cognoscenti said that was not enough for so large a difference in volume, I should be using the 6 ohm connection for the McIntosh speakers.
I am told the lower impedance connections have lower output with higher current.
My lack of electrical knowledge is well known on this forum but it seems to me that IF 8 ohm is the loudest connection, why not leave the McIntosh speakers at 8 ohm and move to Linn’s to say 4 ohm? Then if there is still too much difference, try 2 ohm.
Perhaps there IS a reason to take all the connections to lower impedance setting, I just don’t know.
Anyway care to take a crack at this?
Thanks,
I am having an issue with my internet provider blocking all BeoWorld notifications. This is a test to see if they are coming through.
Still not working so another test.
One more test.
Yet another test......
Four phone calls and four different Techs and my internet server keeps grabbing all BeoWorld notifications. Hopefully this is my last TEST.
