I have a BeoCenter/BeoGram 9500 connected to MasterLink though my house via the old ML converter (1611). My plan is to buy a BeoCenter V1 for the bedroom along with a new BeoLink Converter NL/ML. Anyone know if I'll be able to fully control the BeoCenter/BeoGram though the V1 as I do today though ML? Any other words of advice/warnings? Or should I just leave the V1 as stand-alone and continue to use the BL3500 for bedroom audio?
Thanks,
-- Paul
Hi Paul
That should be possible, a friend of mine has a setup with Beovision 11-46 and a Beosound A6 connected to A Beosystem 7000 and Avant 28 via 1611 and ML/NL, he has full access to all the sources in the Beosystem from both the A6 and Beovision 11-46.
Søren
That's great to hear, Soren.
Anyone else out there have stories of success/failure trying this?
I hat such a combination up and running:
Beosystem 2500 (with connected sources) connected thru a 1611 to my masterlink (a coupe of BeoLink Active 1636) and the Masterlink connected to a V1 using a BLC (ML/NL Converter). Worked perfect!
(By now I have retired the BS2500 and moved on to a Beosounc Essence Mk II)
msinn:(By now I have retired the BS2500 and moved on to a Beosounc Essence Mk II)
So... you don't have a spare BLC lying around do you??
No, since the Masterlink is still in use for the Speakers in tge linkrooms
