Hello,
Any bodies nows what is the difference between beocenter 2 MKI and MKII please ?
Alain SCHROBILTGEN
Found this in my archvies.... (should be on the archive forum ;-)))
There were two versions of BeoCenter 2 (Mark I and Mark II) together with the audio-only version (not fitted with SCART connector).There is the aluminium and steel versions, which looked very similar unless compared side-by-side.The DAB+ was introduced June 2010 (Mark II and audio-only versions).
‘Tactile feedback’ (a slight ‘clicking’ sound when any of the buttons on the BeoCenter 2 facia was pressed) was introduced on the Mark II version.
Hope this helps a little.
Ralf
