Installing the Essence (mk 2) IR eye (SOLVED)
This post has 47 Replies | 1 Follower
abyss
Posts 47
abyss replied on Mon, Oct 17 2016 9:59 PM
No wiring, it comes with the appropriate plug end already installed for use with the essence.
Sal
California, USA
Posts 1,197
Sal replied on Tue, Oct 18 2016 3:20 AM
abyss:
That's great news. Thanks so much!
Razlaw
Posts 4,345
Razlaw replied on Tue, Oct 18 2016 4:49 AM
Dealer also told me it comes fully wired.
Razlaw
Posts 4,345
Razlaw replied on Tue, Oct 18 2016 4:53 AM
abyss:
You need Tor Order the new ir-eye. There is now a join Button (instead of timer i think). As soon you press the Button the essence will join the for ex. Your Moment in the livingroom. Works really well.
Sorry for the late answer, didn't really check the Forum.
Thanks for the picture! Ordered one today.
Millemissen
Flensborg, Denmark
Posts 14,680
Usually the ir-eyes come with the right plug and an 'open' cable end, since they mostly will be installed somewhere.
The cable end must be fittet to the ir-eye then.
See the link that was provided earlier in this thread:
http://archivedforum2.beoworld.org/cfs-filesystemfile.ashx/__key/CommunityServer.Components.PostAttachments/00.00.13.89.94/Schermafbeelding-2015_2D00_07_2D00_25-om-14.56.13.png
Razlaw
Posts 4,345
Razlaw replied on Mon, Oct 31 2016 7:50 PM
Received the new eye that I ordered. Connected wires as the instructions say. Powered off the Essence and turned back on. Green light illuminated on the eye.  Pressing buttons on the eye causes the attached speakers to turn on. But no music. Can still start music with the BeoMusic app.
Tried a Beo 4.  Green light on eye blinks when a button is pushed, blinks constantly when volume up or down is pressed. But there is no response from the Essence to any Beo 4 commands.
Any thoughts or help will be greatly appreciated/
Thanks!
Razlaw
Posts 4,345
Razlaw replied on Mon, Oct 31 2016 9:13 PM
Problem solved. Beo 4 was in wrong Audio Option.
Sal
California, USA
Posts 1,197
Sal replied on Tue, Nov 1 2016 2:26 PM
I'm glad you got it working, Razlaw.
Page 2 of 2 (48 items) < Previous 1 2 | RSS
