Yesterday I connected an Airport Express to the Beocenter 6-23 in our kitchen. I connected it to the AV3 phono connections on the side. All works with one flaw - it seems that it only reacts to the Camcorder input on the Beo4 (which is a LIST button).
Is there anyway to connect the Airport and have it triggered by one of the hard buttons on the Beo4?
E.g.
Scart to 3.5mm adapter (and assigning to e.g. DVD)?(do not have a cable like this but saw it on eBay)
Using the audio inputs next to the Component inputs?
Best regards,
Riven
My B&O products: Beosound 9000, Beosound 2300, Beosound Century, Beolab 8000, Beolab 6000, Beolab 4000 x2, Beolab 3500, Beolab 2000, Beolab 10, Beolink Active x2, Beotime, Beo5 x2, Beo4, A9 keyring x2, LC2 dimmer x6 and growing....
Bought a SCART to RCA adapter on eBay and then connected the Airport using an RCA to 3.5mm cable. Set the input for AV2 as DVD and now I can stream music to the Beocenter 6-23 which is also distributing it to a Beolab 3500 in our bedroom (using the Beo4 DVD button).
Works like a charm.
