Recording via USB BeoVision Avant
lolli998
Posts 28
lolli998 Posted: Wed, Mar 2 2016 11:43 AM
Hi, I have a BV Avant 55" and I checked out the recording feature via USB. I connected my Hard Drive to it and I got a message: use this HDD for records. I confirm and it is formatted in an unknown file system that is illegible to any computer. I try to record and it works but how can I take recorded files out of that HDD?
Thank you all in advantage
BenSA
Durban, South Africa
Posts 1,404
BenSA replied on Wed, Mar 2 2016 12:26 PM
Hi
I think they are trying to adhere to copyright laws. So it will record and let you play on the Avant but it will block you from using it on a computer so that you can't copy or share it.
lolli998
Posts 28
maybe there is a way to by-pass this... I hope somebody knows more about this Avant's feature..
thank you for your reply btw.
jvezina
Montreal, Canada
Posts 200
jvezina replied on Wed, Mar 2 2016 7:11 PM
lolli998:
Good evening,
You may have more luck looking in "underground" forums specialized in cracking stuff than here. B&O must certainly use an off the shelf solution for recording on the hard disk. I suspect the format used is an encrypted Linux/Unix file system.
Good luck,
Jean
Page 1 of 1 (4 items) | RSS
