Beosound Moment & ALAC Support
This post has 1 Reply | 2 Followers
hostler
Posts 49
hostler Posted: Wed, Mar 2 2016 1:19 PM
I'm considering adding a Beosound Moment to my setup. I have no other B&O audio systems at present.
I have a large collection in iTunes, all in ALAC format, but at a variety of bit rates & sampling frequencies.
The bulk of this is from my RIPS of CD's - so 16bit/44Khz - but a growing amount is from Hirez sources (HD Tracks) that i've transcoded to ALAC but retained the bit depth.
The B&O spec for the Moment suggests ALAC is supported (it was;t originally right?) but describes the support as limited to "General and 88.1Khz, 96Khz"
Can anyone expand on that, and build a fuller picture. Does it support >16Bit for example?
Are the limitations down to the Moment or the Twonky DNLA software that bridges iTunes & the Moment.
Many thanks
mbolo01
Louannec - France
Posts 2,035
mbolo01 replied on Wed, Mar 2 2016 2:09 PM
Hi - I have 24 bits ALAC sitting on my QNAP/Twonky and perfectly rendered by the Monent
Page 1 of 1 (2 items) | RSS
DigiCert Secured Site Seal
