BLGW - costum string – http request as a trigger for a button feedback in the beolink app
This post has 3 Replies | 2 Followers
beoandy
sissi not kangaroo
Posts 329
beoandy Posted: Sat, Mar 5 2016 11:39 AM
Hi, I upgraded from the mlgw to the blgw. I also use the lightmanager air to control all my lights in the flat. I use custom strings like POST /control?key=10 HTTP/1.1\0D\0A\0D\0A to control the lightmanager with the blgw. That is still is very good working.
Now I have the possibility to send http requests back from the lightmanager to the beolink gateway to get a trigger for buttonfeedback in the app. Therefor I need a http request send to the blgw.
Enclosed you see a screenshot of the software of the lightmanager. I can fire PUT and GET requests.  (the example shows the string for the Philips hue)
I now look out for a simply string  that can send back to the blgw and can be captured for a trigger.
Beocare says there a two possibilities:
A)   hex based mlgw protocol  on port 9000  http://mlgw.bang-olufsen.dk/source/documents/mlgw_2.24b/MlgwProto0240.pdf
B)   HIP protocol on port 9100 (document also enclosed)
I reed the documents to both protocols, but I need now a pair of  fully strings to see how they single parts must be put together.
For the mlgw protocol I can deactivate the authentication (for testing) but in the final string i must the authentication integrate in the string.
Thanks for your support!
beoandy
BS Ouverture, BS 9000, AV 9000, Avant 32 DVD, BV9, BV6-22, BS 5, BS 4500, BS 7000, BC 9500, Beo6, BL Penta, F1000, BLGW, etc....
beoandy
sissi not kangaroo
Posts 329
and here the documentation for the HIP protocol on port 9100
beoandy
sissi not kangaroo
Posts 329
beoandy replied on Wed, Mar 9 2016 3:16 PM
any hints? Whistle
mjmedlo
Posts 922
mjmedlo replied on Sun, Mar 27 2016 2:46 PM
I can't help on this one.
Sorry
Page 1 of 1 (4 items) | RSS
