Beomaster 8000 remote repaire
Egomon
Posts 39
Egomon Posted: Sat, Mar 5 2016 12:11 PM
With my troubled Beomaster 8000 also came the remote and it had issues as well. Only volume and PH and TP2 worked, so I was thinking that there might be a crack on the board.
[View:http://archivedforum2.beoworld.org/themes/hawaii/utility/:800:0]
I removed the isolator and added some led to the cleaned new tabs.
And soldered jump wires to get the board lines to connect again:
It was easy 10 minute job and now the remote works again correctly
chartz
Burgundy, France
Posts 4,171
chartz replied on Sat, Mar 5 2016 2:18 PM
Well done!
Jacques
Jason
Redditch Worcestershire
Posts 177
Jason replied on Sun, Mar 6 2016 11:40 AM
If you haven't already, it's worth replacing the battery connector , I've seen a few of these that come apart
regards Jason
Page 1 of 1 (3 items) | RSS
