BeoVision 6 26 set top box
BobDewdney
Posts 1
Silver Member
BobDewdney Posted: Sun, Mar 6 2016 10:44 AM
Hi, I have just bought a BeoVision 6 26 for use in my bedroom.  I am based in the UK. I would like to use my Beo 4 to control a STB. None of the STB's listed on the TV appear to be readily available to purchase. How can I be certain to buy a new STB that will wrk through the Beo4?
Millemissen
Flensborg, Denmark
Posts 14,680
Hi Bob,
most likely the STB-chip in the tv would have to be upgraded to a new (the latest) one. Please ask your B&O dealer which boxes are supported!
However - supposing that your BV6 has no HDMI port - it will be hard to find a newer box, that has the needed scart input port.
There are some workarounds using the DVI-input (HDMI TO DVI adapter) and the analogue or digital audio-input - or using a HDMI to Scart converter (or HDMI to Component plus audio converter)!
Or you could be lucky and find an older (preowned) box, that matches one of the entries of the built-in STB-chip.
Page 1 of 1 (2 items) | RSS
