Beocord 3500 Tape Deck
This post has 5 Replies | 2 Followers
nightcountry
Posts 9
nightcountry Posted: Tue, Mar 8 2016 8:57 PM
Could someone explain how I hook up a Beecord 3500  tape deck to a regular stereo so that I can record and play back the tape deck on the system - I see 5 pin din female to 2 rca but I think I would need 4 rca, two for play output and two for record input back to the din plug. The tape deck has a cable attached terminating in a male 7 pin din.
Thank you
ProGram
59269 Beckum, Germany
Posts 383
ProGram replied on Wed, Mar 9 2016 5:23 AM
Usually you should be able to unscrew the 2 extra pins, then you have to use the 4 cable adapter just the way you explained.
Chris
nightcountry
Posts 9
Thanks but which pins would I unscrew?
RaMaBo
near Munich
Posts 626
RaMaBo replied on Wed, Mar 9 2016 2:15 PM
Pin 6 and 7, those are the beginning and the end of the round line formed by all the pins.
Ralph-Marcus
ProGram
Posts 383
ProGram replied on Wed, Mar 9 2016 3:56 PM
There are only 2 pins with a slot to use a flat (small) screwdriver
nightcountry
Posts 9
Thanks all for your help.
Page 1 of 1 (6 items) | RSS
