Right, so when doing maintenance on one of the "sliding glass door" models, what's the best kind of lubricant to put on the rails after cleaning off the gunk and dust? I've heard silicon spray lubricant, but wanted to check.
Do we know what was used initially in the factory?
Found it! "Barrierta Grease L 55/3" is what the manual specifies.
