Beosystem 2500 few issues
This post has 4 Replies | 0 Followers
nanan
Posts 50
nanan Posted: Sun, Mar 13 2016 9:09 AM
I'm new here, and I already own a beocenter 9300 and a beosystem 2500.
Since last week I have two problems with my 2500:
1. The Tape is not working
2. The remote is not controlling the beosystem anymore (but the remote is working on my 9300).
I took apart the tape module and the belt is here, not broken. I'm going to change it anyway (do you have a good belt provider to avise ?)
For the remote, I don't know what to do .. Is there a method to re-sync the remote with the beosystem ? Or the receiver of the B&O is out ?
Thanks for your help.
Regards from Switzerland.
ipaul
Posts 422
ipaul replied on Sun, Mar 13 2016 9:42 AM
Hi, i just left Switzerland, it's a small world, isn't it :)
abt your issues:
1-what does it do and what not, Martin/Dillen here on the forum used to suplly belt sets but otherwise just PM me.
2-maybe somehow the option changed (pr was it linked to another beosysten/tv as a ml-slave), try changing the option.
which remote you use ?
you should be able to find  the way to do this quite easy on this site.
nanan
Posts 50
nanan replied on Sun, Mar 13 2016 4:41 PM
Yes, it's a small world.
For the tape, I did a video, I think it's better this way.
http://www.dailymotion.com/video/x3xk31t
http://www.dailymotion.com/video/x3xk3ae
About the remote, I'm using a beolink 1000, I checked in the manuals (beolink + beosystem) and I didn't find the way of changing the option. I'll have a look on this web site.
Thanks and sorry for my bad english.
nanan
Posts 50
nanan replied on Tue, Mar 15 2016 8:46 AM
So I solved my remote problem:
With the Beosystem in stand-by, I presse SOUND and 1 and STORE, and BOUM !! it works !
Now if there is a tape reader expert that can tell me what to do with mine.
Thanks !
nanan
Posts 50
nanan replied on Sun, Aug 28 2016 4:19 PM
Belt changed and few soldering redone. And the tape is back in the business.
Page 1 of 1 (5 items) | RSS
