Hi, I currently have a beosound 5 encore connected to beolab 6000 wall mounted. I would like also to connect an apple airport express. So my question is, is it possible to connect the beolabs to the apple airport express through the line in at the same time being also connected to the beosound encore through powerlink. Of course I will only be using one at a time, as I know both cant be used at the same time. But since the encore has lost the abilitlty to connect to the bbc radio stations, I want to use my ipad through the bbc iplayer connected to the airport express to use the beolabs from time to time, and then on other occasions use my beosound for my music collection.
thanks
Current b and o Products
beosound 5 encore, beolabs 6000, beogram 4500, playmaker mk1
You can't/shouldn't use your speakers that way.
But the Encore has a line-in connection - just use that for connecting the output of the APE.
Millemissen,
I never even thought about doing it that way, thats a great solution and as the line in is in the back I can hide the cable.
Thanks very much
