beolab 8000 humm, brum..ect
This post has 9 Replies | 0 Followers
marexy
Posts 710
marexy Posted: Tue, Mar 15 2016 9:24 AM
HI
Has anybody correcting this error.
I am convinced that the problem is with RCA connection.
May be a bad contact or kondezator error or else?
Does anyone know what it takes to do it to fix problem?
Nowhere in the forum I have not found anything concrete regarding fixing problem.
I also have a BeoLab 6000, there is no problem when the RCA are coupled.
Thank you.
marexy
Posts 710
marexy replied on Wed, Mar 16 2016 10:37 AM
hi
non of you try to fix these problem ??  :(
marexy
Posts 710
hi
Andrew
Frinton, UK
Posts 917
Andrew replied on Wed, Mar 16 2016 3:33 PM
Could be loads of things, where the cables are run, are they near any transformers etc? length of the cable - perhaps it is picking up interference? Is it the source? could even be the power supply if the speakers are plugged into a multi strip socket.
I would start by seeing if they hum with power link cables, if you haven't got any then maybe shorter or different RCA cables, if it's not that then the power source, if not then try a different sound source if not that and they are still humming then maybe they need looking at by an engineer?
Beobuddy
Utrecht, The Netherlands
Posts 3,972
Beobuddy replied on Wed, Mar 16 2016 4:33 PM
I solve loads of problems like these..
This problem can be caused by several things. Foamrot, Loose RCA, defect switch....
Some people even think that spraying some solvent into the switch, will solve the problem. I would stay far away from this solution.
marexy
Posts 710
marexy replied on Thu, Mar 17 2016 12:30 PM
I fix RCA connector: There is no difference
super duper RCA cables: no difference
repair switch:no difference
someone else has another solution?
marexy
Posts 710
marexy replied on Thu, Feb 9 2017 10:49 AM
Hi
long time ..and have a par with same problem again :(
if i select LINE IN - RCA here we go again ..humm..brumm..ect ..
anyone fix these problem ?
it's interesting...BL 4000 and 6000  no problem with RCA line in
Michael
Sweden
Posts 2,578
Michael replied on Thu, Feb 9 2017 11:17 AM
I have a pair of BL8000 that sounded good when powered on but developed a noise after a few hours of use, every time. It was solved by replacing the amplifiers for new ones. Don't remember the cost now but I think about 800 dollars maybe.
marexy
Posts 710
marexy replied on Thu, Feb 9 2017 11:35 AM
thanks ..
thanks for the advice
I am sure that the repair cost almost null .. if you only know the trick.
But up here it is difficult to know anything...some of the difficult issue are the mystery, unfortunately.
marexy
Posts 710
marexy replied on Wed, Oct 25 2017 8:47 PM
Hi
I have a pair of BL 8000 with serial No 1043.... and 1464...and on both is the same problem.
50Hz humm it is very bad at the RCA input but also on the powerlink.
I did try to change cables ..and surce ....the humm is still there.
And is the only option to give new internal wiering ?
How did you fix these problem ?
Thanks for help :)
Page 1 of 1 (10 items) | RSS
