Hi
My BeoRemote One is driving me a bit crazy. Its always rebooting itself. Every time I press a button "bang&olufsen" comes up and then I have to wait. I changed the batteries from another remote that worked perfectly. It still does it. Come to the point where I use it to switch the TV on then use the B&O remote up on my phone. Sometimes I press it and it does nothing as well just a blank screen on the remote.
Any ideas on what the issue could be?
Ben
BenSA: Hi My BeoRemote One is driving me a bit crazy. Its always rebooting itself. Every time I press a button "bang&olufsen" comes up and then I have to wait. I changed the batteries from another remote that worked perfectly. It still does it. Come to the point where I use it to switch the TV on then use the B&O remote up on my phone. Sometimes I press it and it does nothing as well just a blank screen on the remote. Any ideas on what the issue could be? Thanks Ben
You will have it replaced under warranty, for sure.
Livingroom: BL3, BL11, BV11-46 Kitchen: Beosound 1 GVA, Beocom 2 Bathroom: M3 Homeoffice: M3, Beocom 2 Library: Beosound Emerge, Beocom 6000 Bedroom: M5, Essence remote Travel: Beoplay E8 2.0, Beoplay EQ, Beoplay Earset
Thanks Hiort
I have phoned B&O. The guy that answered has never heard of this issue and says the technician will have to phone me tomorrow as he is out. So I will wait to see what happens with that. Quite frustrating as the remote is virtually unusable.
