Beolab 90 Room Calibration
Mr 10Percent
So West, Its Now East
Posts 591
Mr 10Percent Posted: Thu, Mar 17 2016 10:52 AM
I see a new training video has been posted regarding the BL90 room calibration
https://www.youtube.com/watch?v=O8WQJzoIWBg&list=PLRPmJ785xnMgKXR3KgtScgvPf-V4sWa08&index=15
Weebyx
Denmark
Posts 1,213
Weebyx replied on Fri, Mar 18 2016 4:45 PM
For a speaker costing that amount of money, this is insanely complicated !!!
Should just be via a wireless microphone, nothing else..
/Weebyx
Millemissen
Flensborg, Denmark
Posts 14,680
Weebyx:
/Weebyx
'Just via a wireless microphone, nothing else' - how would that work, then?
Sal
California, USA
Posts 1,197
Sal replied on Fri, Mar 18 2016 5:40 PM
Millemissen:
The speaker would have all the necessary software / hardware built in. For a speaker at this price point, I was surprised at the complexity of the room calibration process as well. Though, since these speakers wouldn't be moved often after set up, if at all. The room calibration as a one time event makes sense (hence, okay for it to be this complex).
Weebyx
Denmark
Posts 1,213
Weebyx replied on Fri, Mar 18 2016 8:02 PM
Sal:
Millemissen:
Maybe the room and furniture might change over time, then it would be cool to just pull out the included microphone and press "calibrate"
I have seen surround receivers 10 years ago with this functionality .. Although wired microphone..
/weebyx
Mr 10Percent
Posts 591
The system comes with a "welcome pack" which is a shorter version of the microphone in the video. It plugs into an RJ45 socket on the master speaker. I'm guessing you can add further calibration data (up to 20) with that and add these settings to either the speaker groups in a bv or to the app that will shortly come with it.
Ditlev
Posts 62
Ditlev replied on Thu, Dec 20 2018 11:11 PM
Mr 10Percent:
My BL90s did not come with that welcome pack? No microphone etc?
D
Mr 10Percent
Posts 591
That’s because you have to part with another £40-odd quid if you want the official mic. Unbelievable.
However, the installers will calibrate it with their gear as a one-off I believe?
I suppose if you don’t plan moving or doing recalls yourself it’s ok?
I purchased mine but I also received a FOC service skate kit (£360)
AdamS
Posts 373
AdamS replied on Fri, Dec 21 2018 1:15 PM
I'm confused as to how plugging a microphone into one speaker, activating the caibration in the app, then moving the microphone and repeating the process twice more is "insanely complicated"? Frankly I found the hardest bit was trying not to sneeze during the calibration!
Unlike all those A/V receivers in the past where the processs generally involves running the calibration, then going round all the channels and correcting them, as the auto settings it chose are so far out that it sounds terrible.
Page 1 of 1 (9 items) | RSS
