I have bought a BEOSOUND 5 ENCORE but the distance between the BEOSOUND 5 ENCORE and the power supply is bigger than then the lenght of the powercable (cable for 7V - 30V with special connector on BS5E). Type of cable (written on the cable : E168141 AWM STYLE 2725 VW-1 80° 30V BAOHING with 8 red wires for 30V, 4 for 7V, 1 shield and 1 black ON/OFF. Does anyone know if it is possible to buy a longer cable, to lenghten the cable or can I use another type of cable,thanks in advance,Louis.
