Beovox speaker stand specs...
This post has 10 Replies | 1 Follower
2121marty
Posts 82
2121marty Posted: Wed, Jul 11 2012 7:03 PM
Hi, I am struggling to find speaker stands to go with my Beovox M150's, well, any I can afford anyway. So I was thinking about making some, as close as possible to the originals. Does anyone have any specification details for Beovox speaker stands???? With accurate info like frame gauge, tube wall thickness and precise dimensions????....
Søren Mexico
Mexico City
Posts 6,411
I made these for my S45s, check the footprint of your speaker, make the base same wide, and some 30 Mm shorter front to back, measure highs to holes for stand screws on speaker, add 200 to 250 Mm (distance to floor), that will be your upright lengths. And check the hole distance. All screws are M5
2121marty
Posts 82
2121marty replied on Wed, Jul 11 2012 8:47 PM
Cheers for the info and pics, looks like you made a very good job of them!
Do you think I might be better off to increse the frame size to maybe 30mmx20mm or 25mmx25mm given the weight of M150's, best part of 20kgs each!
Ahhh.... another project....
Søren Mexico
Mexico City
Posts 6,411
2121marty:
30 x 20, will look better in my opinion, and 30 x 20 will give a more stable upright.
I had a 3 year old kid hanging on my S45s so strength is no problem.
2121marty
Posts 82
2121marty replied on Wed, Jul 11 2012 9:15 PM
Ah yes forgot about the upright, thanks for that, will source box section that is not square, to aid strength... thanks again
Søren Mexico
Mexico City
Posts 6,411
Here a pic finished with gray hammered spray paint, as far as I know the 150 stand originally was black, charcoal or dark brown.
Torben TOFT
Brussels, Belgium
Posts 2
Hej Søren,
Du vil vel ikke dele tegninger + dimensioner, så jeg kan lave mig et par selv? mvh Torben
Søren Mexico
Mexico City
Posts 6,411
her er tegningen til foden til Beovox S45, til Beovox 150 skal du nok bruge 20 x 30 firkantrør. Mål bredde og dybde af højtaleren, lav foden samme bredde og dybden ca. 25 mm kortere, for standeren, mål fra bunden af højtaleren til montage huller, lav standeren 250 mm længere, højtaleren vil så være ca 230 mm over gulvet, eller reguler længden til den højde du foretrækker.
Jeg lavede en "næse" på mine, men du kan også svejse T stykket direkte på standeren, mål hulafstanden på dine højtalere og tilpas T stykket derefter, pas også på at du får tiltskruen på det rigtige sted
Sådan
Torben TOFT
Brussels, Belgium
Posts 2
Mange tak
sonavor
Texas, United States
Posts 3,732
sonavor replied on Mon, Jul 2 2018 8:32 AM
A while back I measured the stands for my MS150s.
sonavor
Posts 3,732
sonavor replied on Mon, Sep 27 2021 6:54 PM
A correction on the angle degrees measurement of the vertical part of the stand that the MS150 attaches to...
Measuring it again, after all these years, the angle is 1.3 degrees.  Not 19 degrees as shown on the photo.
-sonavor
Page 1 of 1 (11 items) | RSS
