Hi can anyone tell me what I would need to connect beolab2000 to my beosystem 2300,,I have looked at back of hi-fi and only has aux socket.I think I need a convertor can someone plaes explain exactly what I would need plaese!
Also are the beolab2000 ok for sound will be using in kitchen/dinning room ?
Hi there.
You need a Beolink Converter. You can find a description on the Main Site under 'Products'. Use the search function.
They sound very good - they'll be great for your kitchen/dining room.
