Among other things,:
After upgrading I had to empty the Beomusic cache on my iPhone to get it to work properly.
Livingroom: BL3, BL11, BV11-46 Kitchen: Beosound 1 GVA, Beocom 2 Bathroom: M3 Homeoffice: M3, Beocom 2 Library: Beosound Emerge, Beocom 6000 Bedroom: M5, Essence remote Travel: Beoplay E8 2.0, Beoplay EQ, Beoplay Earset
Thanks Hiort!
'Multiroom screen in portrait mode - access it from main screen by using the 'Link' icon'
I see no icon?
Tried to clear the cache through Settings -> Beomusic -> Clear cache with no result.
Could you explain more? And post a screenshot with that 'icon', maybe
Millemissen: Thanks Hiort! 'Multiroom screen in portrait mode - access it from main screen by using the 'Link' icon' I see no icon? Tried to clear the cache through Settings -> Beomusic -> Clear cache with no result. Could you explain more? And post a screenshot with that 'icon', maybe MM
The App gui has not changed. The link icon is the same as before (see to the left of the devicename "Bibliotek)
This is the portrait screen. Its now more clear that my Moment is integrated with the BV11.
Oh, that one ---- got it, thanks!
I like it ;-)
mbolo01:We are getting closer to a full landscape mode now that the full portrait is out
I agree to that, hopefully, there will be a landscape-mode again.
I've recognized another new feature. Sometimes it seems, that the BeoMusic-App can not find any device.
There are 2 reasons for that:
1. Mostly - you are not in the same network. Therefore, the new BeoMusic-App shows you the SSID of your WLAN - just to give you a hint, why you cant see your B&O-devices.
2. It's a Twonky-Server-Issue. If you don't allow new devices to connect to the server automatically ( because you set the "sharing devices" to manual) you have to allow your phone/tablet to connect to the server. If you fail to do so, the BeoMusic-App will not show the BS-Moment. Or other NL-devices
Btw., i updated the Twonky-Server to 8.2.1. Now sonos is implemented & the good news is, that there was no need to start a new rescan/refresh in the content-section on the BS-Moment. Everything worked fine after installing the new version.
The same goes for the latest OSX-update. No troubles at all with Twonky or iTunes.Soplease go ahead - don't be afraid.
Cheers Beroli
Another great upgrade:
It supports multitasking much better. You can go from beomusic to any other app and back, without having to wait for it to load the products again. Big improvement for my personal use!
CasperI:Another great upgrade: It supports multitasking much better. You can go from beomusic to any other app and back, without having to wait for it to load the products again. Big improvement for my personal use!
