Penta 1 pop goes the red light
westy12
Posts 5
westy12 Posted: Fri, Jul 13 2012 8:34 PM
Just been gifted a pair of penta 1s - very pleased and grateful but suspect I already have a problem. One works fine, converting from red to green light with input  and sounds great but the other seems dead. The red light came on when I switched on but then, after about ten seconds, I heard a very quiet pop and the light went off. No sound output at any time.
I'm only a newbie with these but have done plenty of soldering and electonics in the past. Assume there must be a fuse in the amp, but clearly there is likely to be a reason why the fuse blew in the first place and don't want to damage anything further down the line!
Any suggestions on a logical, step-wise approach after the fuse without going straight to replacing all of the capacitors?
Cheers,
Paul
pepps
Kent, UK
Posts 116
pepps replied on Sat, Mar 22 2014 8:28 PM
Hi - did you ever sort out why your 'red light problem' happened?
I think my Penta did something similar today - the LED was red for 3 or 4 seconds, then it went out - nothing since.
I'd love to hear how you fixed yours - if you found a way.
Julian
Dillen
Copenhagen / Denmark
Posts 13,191
Dillen replied on Sun, Mar 23 2014 6:23 AM
Check for cracked solder joints where the ribbon cable from the fold-out front panel
goes to the main amplifier board.
pepps
Kent, UK
Posts 116
pepps replied on Sun, Mar 23 2014 6:33 AM
Thanks - will do just that.
Julian
westy12
Posts 5
westy12 replied on Sun, Mar 23 2014 9:28 AM
Ah - took theeasy way out by removing the amplifiers and running as passive speakers.
Hope fix works for you.
Paul
pepps
Kent, UK
Posts 116
pepps replied on Sun, Mar 23 2014 7:59 PM
That's certainly the easy way out :)
I'll let you know how I get on.
Page 1 of 1 (6 items) | RSS
