DTB Button on Beo 4 no longer activates the tuner after software update on Beovision7-32
This post has 2 Replies | 3 Followers
Oktogo
Posts 1
Oktogo Posted: Sat, Jul 14 2012 4:31 AM
Hi there,
.A couple of years ago I had the DVB HD module installed in my Beovision 7.32.I recently downloaded the latest software for the Beovision 7-32 and installed it. However, when I turned on the television I found the DTV button on the remote no longer activates the tuner. When I go to the tuner setupp under the options section of the menu it now says that the DVB T/C can't be found.
Is there a way to reconnect the tuner to the DTV button through the remote control. Does anyone have any suggestions?
Regards,
Oktogo
madskp
Denmark
Posts 321
madskp replied on Sat, Jul 14 2012 9:37 AM
I have experienced this behaviour on a BV6 26". I think that it might have helped unplugging the mains for a bit, or else I tried the software update one more time and then got it working
madskp
Denmark
Posts 321
Page 1 of 1 (3 items) | RSS
