Newbie help needed!!
olistb
Posts 6
olistb Posted: Sat, Jul 14 2012 8:16 PM
Ok so I have just bought a bv7 32 mk4, with beo 4 all second hand. All looks shiny and nice however I seem to e having some issues setting it up.
All I want to connect is my Xbox 360 and pc. I thought this would be simple.
I plug in my Xbox via an hdmi to dvi cable and turn on the tv. I press menu/options/connections abd choose av1. I then change the source to v.mem and change HDTV to dvi-I. And nothing happens when I goto any of the tv DVD radio buttons on the remote. The Xbox is only set to output 720. Am I missing something very obvious or is it something more complicated?
Any help would be appreciated.
elephant
AU
Posts 8,219
elephant replied on Sun, Jul 15 2012 2:41 AM
Hi & welcome to Beoworld
Looks like you have a nice setup - congratulations
olistb:
It may be that the DVI will not carry the audio that comes from the HDMI - but that is not the big problem right now.
olistb:
On some BeoVisions (e.g. my BV8-40) some of the AV processors have extra functions, so for example my AV3 presents a different set of options when you define it as a PC like device, but for the moment let us try to get AV1 working for you.
olistb:
From this description it sounds like you do not have [V.MEM] set inside your Beo4's [LIST].
Check this by repeatedly pressing [LIST] (until you see you are back at the start) and see if [V.MEM] appears.
If it does appear, press (GO) to activate the V.MEM definition in the BV7, from then on your keys will have a V.MEM AV context.
But if [V.MEM] does not appears when you [LIST], [LIST], [LIST] then you need to add [V.MEM] to the list, so follow these steps:
  1. press [LIST] and standby (the red/orange dot button) simultaneously (or hold down [LIST} and then press standby :-))
  2. when [ADD ?] appears in the Beo4 display press (GO)
  3. you will then get a soft key option to add to your Beo4's list, if it is not V.MEM press [LIST], [LIST] until you find V.MEM
  4. now press (GO) to select V.MEM and have it added to the LIST
  5. now you should be back in normal operations mode, so press [LIST] and you should immediately see [V.MEM] in the display as it is the most recent addition to the list
  6. now press (GO) and hopefully voila you have your XBOX display on the screen
BeoNut since '75
KingOfSnake
Posts 162
If you have bought the remote supplied with the TV, assuming it is a MK4, the V.MEM will be found under DTV, that's the simple stuff out of the way.
On forums one needs to be very clear - TV/DVD/RADIO buttons won't do much since you are trying to access the source you have identified as V.MEM!
My concern is that the 7-32 is either a MK1 without the HD upgrade (I mean uprated Scaler Board as some might say!) or that the board itself is faulty.
1) Try re-booting your XBOX and see if it is a hand-shaking issue
2) Advise the first four digits of the serial no and type no
You are either missing something very obvious or regrettably it is something more complicated!
Rikard
Sweden
Posts 218
Rikard replied on Sun, Jul 15 2012 8:26 AM
Is the setup in the TV done correctly?
You have to tell the tv what source (V.mem, DVD etc) goes to witch connector in the back (Av1, Av2 etc) is this done correctly?
Rikard
Sweden
Posts 218
olistb
Posts 6
olistb replied on Sun, Jul 15 2012 10:09 AM
Beo-ed many thanks for the detailed response. I managed to get my pc connected thought a VGA to dvi connection. Set DVD as my source abd hdmi for HDTV. Unfortunately I have had no such luck with the Xbox or my my virgin hd box.
I am slightly more enlightened about the process now. However I seems to be missing some vital peices of knowledge. Right now I have devices connected to the component connected and VGA connection. Still unable to see anything from these sources. I think I may have to visit my store for a quick lesson. Many thanks to you all for your responses.
olistb
Posts 6
olistb replied on Sun, Jul 15 2012 10:12 AM
The honest answer is I don't know. I am a very technically capable person but this has me stumped.
elephant
AU
Posts 8,219
elephant replied on Sun, Jul 15 2012 1:10 PM
olistb:
Did you get manuals when you got the Beovision ?
There are two - a User Guide and a Reference Guide.
Take a look here => http://www.bang-olufsen.com/en/customer-service/product-support
BeoNut since '75
olistb
Posts 6
olistb replied on Tue, Jul 17 2012 6:28 PM
To all of those who responded thank you very much. I now have the thing connected to all my input.
I have now come across another issue. One which I feel may quite hard to solve. Quite simply there appears to be a hdcp issue with my virgin media box. I get menu and sound but no image. The box is outputting the correct resolution. I am using a hdmi to dvi cable, and have tried a further 2 hdmi cables with a DVD adapter. My unit is a mk4 So is equipped to handle the hdcp handshake.
Can anyone offer advise?
Page 1 of 1 (9 items) | RSS
