Hi All,
Wondering if you could help. Recently I had an AV company come in and move my Sky box to a rack in the cupboard using Atlona products. The problem is I can view a picture on my TV but the IR is not blasting to the Sky box so I cannot control Sky from my Beo One remote. Note that this setup was working before but I tried to install a connecting block but when I couldn't get the block working, I put the IR wires back into the back of the Atlona switcher and it now doesn't work.
My setup is as follows:
TV: Avant 55
HDMI Receiver: AT-UHD-EX-70C-RX - connected to HDMI 1, PUC cable to receiver for IR, cat 6 to switcher.
Switcher: AT-UHD-SW-52ED 4K/UHD -> Atlona IR blaster connected to IR out port.
Setup on TV -
Product Integration -> HDMI Matrix -> MATRIX CONNECTED HDMI 1 -> PUC AT-UHD-52 -> PUC 2A (HDMI MATRIX) -> Control Type PLUG, Modulation ON.
Source List -> Matrix 1, would you like to control b&o... YES -> PUC Table Thomson SkyHD MkII, using default settings.
However this setup has stopped working, but was working before. Any ideas?
try resetting the TV and removing the box;
also, I've found that atlona must have the correct spec'd IR cables;
might give atlona a call and make sure you've got the correct IR emitter and receiver.
