I have a Beomaster 2400 that when in phono mode works intermittently, sometimes good, sometimes one side only, sometimes not at all. I have had several electronic tech's look at it and they were unable to repair it. They have tried to source the IC chips with no luck.
Does anyone know if and where these parts may be available? Or know of any electronic repair shops that would be able to repair it for me?
I'm from western Canada.
Welcome to Beoworld !What tech guys are they ? The ICs are available if you look for them - but they are not in the signal path.
Thanks Martin glad to be on here. Well obviously they didn't know much about these amps or where to look for parts.
Any suggestions what might be wrong? Everything else seems to work ok on it.
Doug
Piaf will be your best adviser for Canada, but I think he ships his items to Benny Armina
If you can do it yourself best bid is, find the failure, and then get a cap and lamp kit from Dillen, plus other items failing, caps and lamps are essential for these wonderful playing BM 2400
