Beogram 8002
comish4
Posts 16
comish4 Posted: Fri, Apr 1 2016 3:43 PM
Was wondering if anyone knew the value you of value c4  on Beogram 8002 Mine is blown apart and tho I believe it is a.47uf@ 100v replacement just wanted to check before putting it in. Thanks
comish4
Posts 16
comish4 replied on Mon, Apr 4 2016 11:32 PM
yes that is right cap. stuck it in and ifs up and running.
comish4
Posts 16
comish4 replied on Thu, Apr 21 2016 8:17 PM
another question about the beogram 8002 I have a problem with the circuit board the houses the din plug for the output of the table a number  of wires were broken off the board looked at the schematic and not very good at solving this issue. I have it wired from left to right   first solder tab Blue,Brown White, White, ground, ground,grey , Violet, Black. If this is not correct does someone have the correct wiring diagram or can they look at their board and let me know the order....Thanks so much  I have searched the formuns and have found nothing
sonavor
Texas, United States
Posts 3,732
Here is the output board on one of my Beogram 8002 turntables.
sonavor
Posts 3,732
Here is an old picture I found of another BG8002 project. It shows the output board in question and the source of the wires connected to it.
Dillen
Copenhagen / Denmark
Posts 13,191
Dillen replied on Fri, Apr 22 2016 3:06 PM
Not all output boards are the same.
Different types of relays were used through production and the boards differ accordingly.
comish4
Posts 16
comish4 replied on Mon, Apr 25 2016 6:37 PM
Thank you so much for your help and kindness!
stuvw
Posts 5
stuvw replied on Thu, Oct 25 2018 7:52 AM
Hi.
I have a similar problem and I was hoping someone would be kind enough to complete the following diagram by writing in the appropriate numbers.
This avoids the confusion about different coloured wires being used.
I do believe the 3 wires shown on the right, that do not connect between the 2 boards, are however the colours shown on the right.
Thanks for your time.
Stuart.
Page 1 of 1 (8 items) | RSS
DigiCert Secured Site Seal
