Beovox 2500 Cube Wiring
This post has 4 Replies | 0 Followers
Ben_S
UK
Posts 631
Ben_S Posted: Sun, Apr 3 2016 11:12 AM
Dear All
My Beovox 2500 need their wiring replaced. I see that the wiring goes through the metal centre of the cube.
Does the metal pole unscrew from the cube itself to reveal the wiring? I don't want to force anything!
Ben
chartz
Burgundy, France
Posts 4,171
chartz replied on Sun, Apr 3 2016 2:09 PM
You have to remove a tweeter. Have a look here and there.
Jacques
Ben_S
UK
Posts 631
Ben_S replied on Sun, Apr 3 2016 2:11 PM
Thanks Jacques!
Yes - thumbs up
chartz
Burgundy, France
Posts 4,171
chartz replied on Sun, Apr 3 2016 2:13 PM
Do be extremely careful when you pull the grille: I used a hook (a paper-clip, really) and used two holes of the cover to pull it. It should show some resistance because it is glued in place.
Also, be careful not to pierce the cone!
Oh, and replace the cap while you're in there!
Jacques
Ben_S
UK
Posts 631
Ben_S replied on Sat, Apr 9 2016 7:39 PM
Thanks Jacques,
all good advice, and I will replace the cap!
Ben
Page 1 of 1 (5 items) | RSS
