thinking of upgrading to bv7-40 mk2
This post has 7 Replies | 2 Followers
Nick
Nottingham
Posts 785
Nick Posted: Sun, Feb 5 2012 2:58 PM
Hi all,
  As stated in my title I am thinking of changing to a 40" version of my 7-32 mine is a mk1 model!
Does anyone think i would notice any benefits if i get a mk2 version of the 7-40?  This is in my budget, as the mk3 is vastly more due to having the built in bs3!
Let me know what you think guys?
Cheers Nick
Ƨcɑɽɑɱɑnɡɑ
Khao Phing Kan
Posts 6,662
One benefit you would notice... about 8 inches!
Wink
Wink
  • One B&o bottle opener
  • One fancy gun
valve1
The south of France and occasionally Dublin Ireland
Posts 1,502
valve1 replied on Sun, Feb 5 2012 3:19 PM
Hi, I think the bv7 is fantastic bit of kit and it was the software issues that put me off. If the mk 2 is all your budget will cover I would get it as you can always trade the panels up later.
Nick
Nottingham
Posts 785
Nick replied on Sun, Feb 5 2012 3:21 PM
valve1:
Thats the plan I would love the mk3 as its full hd and hdmi.  I love the design of the set and my 32 seems small by todays standards
Seanie_230
UK
Posts 2,278
Hi there
I love the BV7
i have the same stand and now am on the MK4.
I tend to upgrade just the panel every 2nd/3rd revision to save money and keep up to date.
MK2 does give advantages over the 32" but from memory i cannot remember what they are.
I know the MK5 has the 100Hz screen and MK6 has 3D
i cannot even remember why i moved to the MK4 i think it was for bluray and something else
Eclipse 65
V1-32
Beosound M5
Essence MK2
BLI
bayerische
Ekenäs, Finland
Posts 4,770
I would think the biggest benefit would be the 8". IMHO, as a living room TV a 32" is by todays standards very small.
BS3 would probably be nice, but if it's out of your budget, I wouldn't worry too much about it.
Too long to list....
Nick
Nottingham
Posts 785
Nick replied on Sun, Feb 5 2012 3:32 PM
Which way would you connect the hd signal, seeing as i can't use hdmi?
Seanie_230
UK
Posts 2,278
IIRC i had to use a HDMi to DVI cable on the MK2 i had as it had no HDMI but did support HD via DVI.
yeah that was why i moved to the MK4 for HDMI
Eclipse 65
V1-32
Beosound M5
Essence MK2
BLI
Page 1 of 1 (8 items) | RSS
