I currently have the BeoPlay S3 speakers (2 of them) and have paired them successfully utilizing both Bluetooth and Wired connections with one speaker as the master.
When playing them through an iPhone or MacBook Pro connected via Bluetooth, the paired speaker (even if its paired with a cable) switched off after 15 minutes and you physically have to turn it back on again.
Is there a way to avoid this?
Can the 2 paired S3 speakers just play continuously without one switching off?
Hey there, did you at the end fix your problem or not? Same problem here...
archivedforum2.beoworld.org/forums/p/16666/227836.aspx#227836
peteballoon: This morning (Fri, Dec 8 2017) I received notice that the R&D team is working on an update which will include an option to turn off automatic standby mode. I hope that we'll get to see the new update soon and it will resolve problems with the S3 a lot of people here seem to share with me.
I LOVE YOU Best info of the day...ok and co-worked will bring me food
Hi !
Did you get any solution? I think I’ll try to give them back to amazon, it’s frustating to use them.
