As the perspex and the Nylamid gear are identical, I would try to get one 3D printed
Perspex is also known as plexiglas is mostly used by B&O for covers like on the BGs, why someone with mechanical engineering background would use it to make gears makes me wonder, perspex is brittle and hard, Polyamide (Nylamid) is also known as nylon, has much better mechanical values for making gears and bushings and the like for engineering. The 2 white gears in your pic are made from polyamide
3D printing is fabricating parts with plastics, from a scanning of an original part, or from a Cad drawing, if you search you will find a company or business near your location, that do 3D printing.
Email me...
