I just received a message from Facebook stating that my "Friend" Bang & Olufsen, is now "Friend" with my other "Friend" Spotify...
I just wonder if we can infer that the BS5 and other products will soon support Spotify?
p.
Beoworld app with direct photo upload and emoticons.
Seems to indicate that it may come soon... I wish that it will be available in the Encore, not only the BS5...
On a side note, Sonos is now compatible with Qobuz, which makes it the first system compatible with all 3 major streaming services. (and it's the first time a device other than a computer/smartphone is Qobuz-enabled)
diisign.com
Actually I now realised the "Bang & Olufsen" that friended "Spotify" wasn't the official B&O, but a retailer. Spotify isn't really difficult to implement and B&O should really do it - sooner rather than late.
Ok, false alarm... Maybe in 10 years it will happen
Maybe its more for the B&O Play range guys! B&O are keen on Spotify as the BeoLit 12 has 4 Spotify playlists. I messaged their FaceBook site to request the same for the A8. They didn't even have the decency to reply. HOW VERY RUDE of B&O!!! So much for good PR with future customers! Not very good really is it!
Paul W:BeoLit 12 has 4 Spotify playlists
I am not sure what it means for the Beolit to have Spotify playlist? Can you elaborate?
Yes sorry Phil. I just meant that there are 4 Spotify playlists on the BeoPlay.com website under the BeoLit 12 section :)
I’m not sure either. Beolit has Airplay, and Spotify supports Airplay from any iOS device. What’s your point, Paul?
Im just pointing out that B&O are obviously keen supporters and user of Spotify for them to make playlists for their website so with any hope you BANG&OLUFSEN guys make get ur Spotify on the BS5 :)
Yes, that would be a killer feature, wouldn't it? But using the scroll wheel to search 15 million songs, is that feasible? Adding a Playmaker to your A.AUX seems a lot easier.
