Beolab 20 flashing orange light in the wireless option?
Designed-AV
Sweden
Posts 39
Designed-AV Posted: Fri, Apr 15 2016 8:48 PM
Beolab 20 flashing orange light in the wireless option, otherwise the Powerlink everything works as it should. Has anyone idee to fix this problem? or can anyone upload up service manual to Beolab 20?
zerocool143
Posts 94
You need to repair the software of the Wireless powerlink of your speaker through Service Tool.
Just update your speaker to the latest firware to correct the software.
Razlaw
Posts 4,345
Razlaw replied on Sun, May 29 2016 1:42 PM
I am about ready to order a pair of Beolab 20s.  Reading this made me think of a question. This thread, and I believe posts elsewhere in the forum, have mentioned updates to the Beolab 20s. I will not be using them wirelessly, as they will be connected to my BV7-55 by cables.
Will I still need to do updates on them at any time?  Can I do so without have a newer BV that connects wirelessly to the speakers?
I do have an Essence MKII connected to the aux in of my Beosound 5. Could I reconfigure it to connect wirelessly to the Beolab 20s and update them using it?
Thanks!
Page 1 of 1 (3 items) | RSS
