Hi there,
I would like to know if somehow it is possible to connect a a passive B&O amplifier to a Beolink Wireless, this would allow me not to use a masterlink cable.
Thank you for your responses
Seaocean
Thank you for your quick answer.
In your proposed set up, shall I need one or two Beolink Wireless?
Thank you again for for help as this forum is very useful.
One small note - you cannot use the powerlink sockets on the wireless if you are using it as a mastermind "bridge". At least this is how mine works.
Stan
Stan:One small note - you cannot use the powerlink sockets on the wireless if you are using it as a mastermind "bridge". At least this is how mine works. Stan
BeoNut since '75
elephant: Stan: One small note - you cannot use the powerlink sockets on the wireless if you are using it as a mastermind "bridge". At least this is how mine works. Stan do you mean "if it is configured as the transmitter" ? If yes to that I agree; it was a disappointment to me to find out that the transmitter could not also be in its own link room with its own speakers
No, you cannot use the ML and PL simultaneously on either the transmitter or receiver. See Vienna's detailed response to my recent wireless thread: http://archivedforum2.beoworld.org/forums/p/2126/18375.aspx#18375
