Eclipse 65V1-32Beosound M5Essence MK2BLI
Seanie_230:Hello BeoTeam I need some innovation ideas I have now setup my global cache IP2CC and its talking to my BLGW It's setup in systems I have three resources setup as address 1,2 & 3 which means that on the Beolink app I have three buttons. Each button press turns the relay on and then the same button press turns the relay off. I have connected the relay to my curtain track and when pressed the relay goes on and the contacts the closed making the curtains close. Another on and off makes them open. I need some innovation thoughts for how to set this up I thought about hiding the buttons and having a macro Step1: trigger BV7 command Step2: fire relay button Step3: delay 2 seconds Step4: fire relay button again to turn it off Because the button turns the relay on and off and there is not different relays for open and close it means that if the curtain as are already closed and I have a macro run to automate open and close at specific times it may open the curtains in the evening if they are already closed. Can anyone think of any other way or give me some innovation ideas for things to try. Cheers all BLGW - Rekindling the love of ML
