Sorry to sound so dull but I have just acquired 3 wall brackets for my Beosystem 4500.......is there an easy way to to figure out the distance appart they should be fixed on the wall, ie a template etc?
Cheers
Paul
I must have the original mounting instructions somewhere Paul! If I can find it I will make a scan and send it to you!
Brengen & Ophalen
What can I say....heel erg bedankt!
If Leslie can't find them, then I have them. Just let me know.
Steffen
Thanks Steffen that's very kind. I would like to get my pride and joy on the wall today so......either of you would be great.
Steffen: If Leslie can't find them, then I have them. Just let me know. Steffen
Paul -you have a PM
If anybody else wants it -here it is
Steffan, you are a Gentleman. Thank you very much.
Glad to help you
very much obliged, that's one post I won't have to put up in the future, cheers
Thanks Steffan, will use that soon !
