Beoworld Overture CD not working
milannoir
Posts 20
milannoir Posted: Tue, Apr 19 2016 2:47 PM
Just bought a second hand Beosound Overture. The CD player doesn't load tracks or spin. The laser moves up and down trying to focus for a second or two then nothing. The tape machine works. I cleaned the laser, no difference. Can anyone suggest what is the likely problem before I start opening it up?
Many thanks
CB
> You are Here <
Posts 1,762
CB replied on Tue, Apr 19 2016 3:00 PM
If it's a CDM12 (linear movement) then you'll probably have to replace the unit.
If it's a CDM4 (circular movement), replacing a single electronic component (capacitor) may solve your problem...
milannoir
Posts 20
milannoir replied on Wed, Apr 20 2016 12:07 AM
Thanks, it's a CDM12. Do I have to get the exact same one? - seems there are variants available.
marexy
Posts 710
marexy replied on Wed, Apr 20 2016 12:40 PM
laser unit change...15 USD - Ebay..small problem
CB
> You are Here <
Posts 1,762
CB replied on Wed, Apr 20 2016 6:12 PM
There are several threads on this subject here (new and old forum) like these:
http://archivedforum2.beoworld.org/forums/p/4625/41929.aspx#41929
http://archivedforum2.beoworld.org/forums/p/189/72406.aspx#72406
--> use the search function of the forum with "cmd12"
milannoir
Posts 20
milannoir replied on Wed, Apr 27 2016 1:12 PM
The ribbon reads 3067 EF-20A and the chip is TDA1302T
My research suggests I need VAM1202 unit, am I right?
Also the product info on a VAM1202 on ebay says "To replace the traverse mechanism it is necessary to remove it from the old loader by unsoldering the connections to the spindle motor, sled motor and limit switch"
So there is soldering involved in all cases?
Weebyx
Denmark
Posts 1,213
Weebyx replied on Wed, Apr 27 2016 6:11 PM
Get this one....
http://www.ebay.com/itm/NEW-Original-VAM1204-CDM12-4-05-Laser-Head-Lens-/181308914842?hash=item2a36da7c9a:m:mtAcy4VdwVJ0ZDmKAB0wNkw
I have bought a lot of lasers from here, they work perfect for Ouverture/2300 with CDM12 units....
/Weebyx
Weebyx
Denmark
Posts 1,213
Weebyx replied on Wed, Apr 27 2016 6:15 PM
milannoir:
You do not need to solder... just take out the old unit, remove the back PCB, watch out for the 2 cables, they need to be removed from the connectors by pressing the sides of the connector back towards the cable.. dont just pull !!
Then just remove the motor, the 2 gears, and then the laser it self on the slider... move the slider on to the new laser, and reassemble again..
/Weebyx
Page 1 of 1 (8 items) | RSS
