Would the stands for Beovox S45/S45-2 fit the Beovox S-80?I found few older threads with the similar issues but not the answer to this.
Actually it would be nice to know how many types of those stands for Beovox Uniphase ware available in the 70/80's?I found the post by Martin about type 6013 and 6017 (supposed both fit Beovox S45/S45-2, different only in height). There must be a bigger version for M(S)100/150 too. Type number?And of course there are 2 trumpet stand types.
Anybody knowing other stands? Type numbers? Pictures?
Vintage Bang & Olufsen
Nobody knows if the stands for Beovox S45/S45-2 would fit the Beovox S-80?
Beovox S80 stands will mount to the fittings at the back of Beovox S45.2 but the height would be wrong.
Stand 6012 is for Beovox S75
Stand 6013 is only for Beovox S45.2 type 6312. (There were no square stands for Beovox S45 type 6302 - and no holes provide for it at the back).
Stand 6017 is for Beovox S55 / 80 / 80.2 / 120 (and I seem to remember also S45 (type 6427).
The M75 and M100 uses black stands with bigger footprint (Type 6010 if I remember correctly).
Beovox M150 uses larger and higher stands
Beovox MS150 again larger and higher.
- The above are from memory - there are more...
Hi Martin,
thanks a lot for answering my first question.
So I tried to consolidate your information about the stand types in this table:
Normal 0 21 false false false DE-AT X-NONE X-NONE
Stand types vor Beovox Uniphase speakers
Stand (type)
Color
Speakers
Note
6012
silver
Beovox S75
6013
Beovox S45.2 (type 6312)
6017
Beovox S55 / 80 / 80.2 / 120 (also S45, type 6427)?
6010?
black
Beovox M75 and M100
Beovox M150
Beovox MS150
I hope we can find the missing types in future to complete and extend this table. It could be interesting (at least for me) to have it as a reference.
Thanks again.
M75 - stand 6011 - included as standard
M100 - stand 6010 - included as standard
M150 - stand 8960160
MS150 - stand 8960150
Peter
Thanks Peter and Cleve,
here the updated spreadsheet:
Beovox S50 / S55 / 80 / 80.2 / 120 (also S45, type 6427)?
6011
Beovox M75
6010
Beovox M100
8960160
8960150
8906007
Beovox 3800, other?
Trumpet stands
Beovox M70 / S75
If anybody knows the type number of second type of trumpet stands or have other stand types, please write it here. I will update the table.
Thanks again to all.
Was the S75 available with the option of both square and trumpet stands?
Ben
The optional stand for the S75 was wall mounting kit type 6014 - I do not recall any of these speakers having trumpet stands
the_o_master: Thanks Peter and Cleve, here the updated spreadsheet: Normal 0 21 false false false DE-AT X-NONE X-NONE Stand types vor Beovox Uniphase speakers Stand (type) Color Speakers Note 6012 silver Beovox S75 6013 silver Beovox S45.2 (type 6312) 6017 silver Beovox S50 / S55 / 80 / 80.2 / 120 (also S45, type 6427)? 6011 black Beovox M75 included as standard 6010 black Beovox M100 included as standard 8960160 black Beovox M150 8960150 silver Beovox MS150 8906007 silver Beovox 3800, other? Trumpet stands ? ? Beovox M70 / S75 Trumpet stands . . . If anybody knows the type number of second type of trumpet stands or have other stand types, please write it here. I will update the table. Thanks again to all.
I have just purchased a pair of Beovox s75 with stands. To my surprise, the stands are exactly like the ones I already have for my s45-2's. Quite sure they all are type 6012.
Does anyone know the sizes for different stands?
// Henrik
Type 6012 is apprx. 49cm high.Type 6013 is apprx. 43-45cm high.Type 6017 is apprx. 51,5cm high.
Great, many thanks!
Few weeks ago I finally found nice pair of trumpet stands (thanks Dave if you are reading this!).
Now we have also Type number for them (I will update the sheet).
Here the updated sheet :
Theomaster
I found this pic which confirms the beovox types from our sheet for the stand type 6017:
Congrats on the trumpet stands :-)
Could you please tell me the diameter of the round stand? Cheers
