Iso a complete arm unit or a broken Beogram record deck of any type as long as it has the tangential mechanics used in all the latest generation record players.
Donor arm found and successfully replaced :)
thanks to Joeyboygolf/Graham.
I'm glad that you got if fixed OK
Graham
Regards Graham
