Hi everyone,
I am a complete novice when it comes to A/V equipment. So, I figured that if I detailed what I wanted to achieve with the equipment I have someone might be able to help.
I want to get the best quality picture and audio with:
Beovision 7 (model 9334) TV
The speaker that came with it don't know what model,
Sky HD+ box
My netbook with HDMI connection
PS3
Xbox 360
I was hoping to use the DVI input for HD. Could I also ask that you use very basic terms so I don't get confused please
Thank you
Tom
Hi Tom, frankly I cannot understand why the connectivity issues weren't thought about before purchasing, or at least addressed to the seller. You can only accomodate three of your components permanently in 720p/1080i but you'll haveto buy an add-on.
Kingofsnake this TV was given to me. which is better than what i have had originally so im trying to get the best i can out of it. how would you go about connecting it? and what kind of add on are you talking about? i was having a play with it yesterday and have manged to get HD channels and normal channels but have to swap between dtv and v aux2 to get sound on normal channels.
